Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 with no oil coming out of push rods
Old 08-22-2010, 07:21 AM
454C10 454C10 is offline
big blocks don't squirt oil out of the push rods as much as small block.
and tend to barely squirt oil out the push rods at idle.
Is it wet with oil under the valve cover?
pull the valve covers, rev the engine to 2000 rpm and hold it for a few minutes, then look for oil.
also check it see if the all the push rods are spinning.
