454 oil wt question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2012, 07:04 PM
a long time ago i read that theres ( something ) << sorry for sounding stupid, inside of big block motors that are splash fed lubed and that running 30 wt/ 2050, and heavy oils like that wont allow this system to have enough oil thrown on them ?
if someone could answer this id be greatful, being i wont feel so dumb thinking about it =P
i run castrol gtx 20w50 with 1 qt of marvel mystery oil. everything seems to run fine, my truck had 5-30 in it when i got it and it didnt smoke out the exahust even under hard revs. not even with a quart of motor flush and a quart of atf added to clean the PO's neglect
just wanted to know what all of you thought on this
Old 07-01-2012, 07:06 PM
marine motor
the motor in the truck is a 454 marine engine > 5XY application out of a yacht
Old 07-02-2012, 05:12 AM
The cam is splashed with oil. Same on the small block.
I try to run the thinnest oil possible, using hot oil pressure as the factor how thick the oil needs to be.
There is a company called BC engineering that makes an over cam oiling system for the BBC. $60.00 I think. I made my own for about 15. Seems to work well.
BBC's are hard on cams due to the extra lift BBC tend to have. Try to avoid strong springs and aggressive cams (quick ramps and high lift) if you use a flat tappet cam and want your BBC to live a long life on the street.
Plus todays emissions oils don't help either (low on anti-wear additives). ZDDPlus™ - ZDDP for Classic, Muscle Cars & More
Best to use a roller cam and forget about it.
Old 07-02-2012, 07:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Anywhere from 10w-30 to 15w40 should be fine, providing the oil clearances are typical. I suspect you might be a bit on the thick side, but adding a quart of MM oil (about the consistency of ATF if not thinner, IIRC) will lower the viscosity, at least temporarily. How much I cannot say.
The only way I'd be worried- even using the straight 20w-50- would be if the engine was idled excessively. Once the engine is spinning at 2000 rpm-plus, there's plenty of windage blowing oil around. But that said, using excessively heavy oil costs HP and mileage. If there's not a good reason to use such a heavy viscosity oil, don't.
MM oil in and of itself is a poor motor oil IMO. As an additive it may have its place, but I wouldn't run my engine on 17-20% MM oil (1 qt. added to 4 or 5 qts. motor oil) unless the idea was to break down sludge or something like that. I would also expect the naphtha content (70-80%) to evaporate fairly quickly considering how volatile it is, leaving behind nothing but a dose of mineral spirits.
I would use a motor oil that contains the right amount of additives for a FT cam/lifters, or use the recommended amount of an additive like ZDDPlus added to a quality "over the counter" motor oil.
Old 07-02-2012, 08:03 AM
i was thinking
i did think about running 10/40 in the truck instead of the 2050. i baby the truck in all ways so last thing i need is to hurt her internally. she aint much but i saved her from being chopped up and discarded, and shes fun to drive =]
i may change the oil today, theres a bottle of 10/40 in the garage from quakerstate =]
Old 07-02-2012, 08:07 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sounds like a plan
Old 07-03-2012, 09:19 AM
1971BB427's Avatar
If you're running this engine like an old conventional 454 car that has no catalytic conveter, then adding zinc, or using oils with zinc is fine. If it has a converter the zinc will plug it, so in that case you need oils without zinc, or use additives that copy zinc, but are OK with a cat.
I personally run Brad Penn oil in all three of my old flat tappet engine vehicles. I'm using straight 30 wt. all year round, and I have had no problems.
Old 07-03-2012, 09:31 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Obviously the statement above is if you have a FT cam/lifters. If you have a factory hydraulic roller, the over the counter motor oils are OK as-is.
marvel mystery oil, splash lube
454 oil consumption turchiac Engine 20 05-03-2010 07:58 PM
454 uses oil? turchiac Engine 14 01-20-2010 06:44 AM
454 oil capacity turchiac Hotrodding Basics 8 01-19-2010 09:56 PM
454 oil sensors edelbrock3 Engine 3 10-15-2007 02:53 AM
No oil pressure on 454 revconmotorhome Engine 5 05-11-2002 03:42 PM
