454 peanut heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2010, 11:31 AM
454 peanut heads
Hi guys,
Newb here, with a question. I've got a 454 truck engine in my 4x4, looking for some serious grunt power. Just bought a Weiand 177 blower and can't wait to get it on. My question is what would be a good cam for low - mid power. i doubt it ever going to see 5000 rpm. Going to run 38 inch tires with 410 gears so I can cruise highway at 2000 rpm. Engine is all stock exept for try-Y headers, No smog, If I keep boost low, like maybe 4-5 pounds it should bring my compression up just enough to still run pump gas, and ramp up the fun factor. Is it possible to put a cam in that would give me that, and have some rumble?
Old 11-11-2010, 01:14 PM
mud.man.rj's Avatar
blower 454
Go to the comp cams site, I see in a comp cams book I have they have a blower and turbo cam section. If you are going to stick with the peanut heads at least do a little porting an intake port matching to help it all work together better. Sounds cool ,I run a 460 full size Bronco with 38.5 Boggers on the street, fun. Good luck with the blowre, I am thinking of simular on my truck. Let us know how yours works out.
Where can i find hp heads for a gen v 454 Getlow1500 Engine 11 04-11-2008 01:39 PM
cheap 454 with peanut heads Haulin327 Engine 6 05-27-2006 11:06 PM
Can I just “slap” 454 heads onto a 502? Bayley Engine 2 05-15-2006 07:12 PM
66 heads on 74 454? smac Engine 4 02-15-2006 04:55 AM
454 Heads Junk or keepers? roys63 Engine 3 11-12-2002 06:03 PM
