454 piston/rod noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2011, 03:01 AM
i purchased a truck with a knocking 454 cheap because previous owner had just rebuilt it and was a little upset bout the noise. my question is, (are these pistons in correctly) this is first BBC i have been into. i noticed the hole on piston and know that on sbc they go same way . wondering if this is correct or if he put 4 in upside down.i figured the standard block needed bored and my noise is piston slap from ware and honing when he rebuilt it.
ID:	56107   Click image for larger version
Old 06-16-2011, 05:56 AM
BOBCRMAN@aol.com's Avatar
Yes, four pistons are wrong. Which means that the rods probably are also wrong. This could have also caused a bearing or big end rod failure.
Old 06-16-2011, 05:04 PM
Overdriv's Avatar
Looks like 4 pistons are on the rods wrong, but what difference would it make with the valve reliefs in the same relationship with the heads/valves either way they are installed. If the pins are offset, then that makes a big difference, but I bet they are not.
If the rods were installed correctly on the pistons, then four rods would be installed in such a way that the rod bearings on those four would be tight against the crank throw filet. Which would probably push the rod tight against the other rod. Not good and would probably destroy the bearings on all four incorrectly installed rods and probably all eight.
Take it apart and see what is going on.
slight humming noise at idle and knocking? noise on slow acceleration zoomo Engine 13 05-26-2011 11:00 PM
Old TRW Piston Part # 234-98 396 Chevy Forged Piston? heathj1 Engine 1 07-21-2009 06:14 PM
positioning piston rings on piston geormor9 Engine 5 03-21-2009 06:33 PM
RE:Flat Piston To Domed Piston Bgcooley Engine 10 09-04-2007 01:59 PM
Piston noise? lluciano77 Engine 18 11-25-2003 10:42 PM
