454 piston to valve clearance? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2010, 09:25 PM
Im thinking about using this cam (NX279HR) in my 454 with a 177 supercharger with 049 heads and wiseco flattop pistons. Does anyone know if i should have any issues with ptvc? I know that checking is the only way to be sure but i was just curious thanks.
230 int./242 exh
0.537 int./0.541 exh
Lobe separation 113
2,000-6,200 rpm range
Old 09-08-2010, 09:36 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
No living soul has any idea if the block has been decked or if the heads have been cut or if the valve seats have been replaced and sit the valves further toward the piston or what the ACTUAL rocker arm ratio is that you will use (for instance, you buy 1.7 and they ship 1.8) or any other variables involved. So, yeah, check 'em with clay on the pistons and a dial caliper or a dial indicator on the retainer with checking springs.
cobalt327's Avatar
WFO
Wiki Edits: 1616
230 int./242 exh
Lobe separation 113
You should be fine- but accept nothing except physical verification.
Old 09-08-2010, 09:53 PM
Thanks for the quick responses
Old 09-09-2010, 03:54 AM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
I will be working on a 496 in the near future.
What should the clearance be typically for a BBC?
1/8" ?
Old 09-09-2010, 05:21 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
1/8" ?
1/8" would be more than enough. Typically, 0.080" intake and 0.100" exhaust will be plenty safe. If you use modeling clay, rotate the engine two full revolutions to be sure.
Old 09-09-2010, 10:53 AM
123pugsy's Avatar
Wiki Edits: 29
The dial indicator seems the easiest way to go.
Old 09-09-2010, 06:42 PM
Senior Curmudgeon
Wiki Edits: 326
The closest near miss will usually be at the exhaust valve during the overlap period, with the piston chasing the valve back onto its seat.
Correct way to set valves on sbc w/ solid flat tappit camshaft? Joshua Lee Engine 17 02-09-2011 05:55 PM
Cam Help shsouthard Engine 18 03-29-2009 09:33 PM
Piston to Valve Clearance - How to Check Before Ordering New Cam leejoy Engine 10 12-03-2007 11:14 AM
327 in 88 Truck pete379 Engine 101 01-19-2006 09:03 PM
Valve piston clearance cuda66 Engine 4 03-17-2004 02:46 PM
