Both areas look to be normal casting issues. If worried, load it up and take it to a machine shop. I recall grinding a BBC main cap around the driveshaft and dont think it is a problem.
You're all worried over nothing, and you don't need to put new caps on the block, there is nothing wrong with the cap you have. The area you are worried about chipping in the cap is a non-load and non-locating area, the chipping is just the consequence of drilling a hole through the edge of a casting and in all likelyhood happened when it was machined at the factory, 90% of the caps you check will be the same way, and was that way right from the factory. As a matter of fact, a race engine builder would take a Dremel to that chipped area and carve it smooth slightly into the thicker section of the cap material around the hole, making the hole bigger but removing any thin metal that may be subject to coming loose in the future, just to be safe.
Same deal with the oil drain hole in the head, it came cast that way and who knows when the edge of the hole chipped, but any engine builder would get in there with a Dremel or die grinder and cut that casting flash back to more solid metal just to prevent any chance a another small piece of this thin left over casting material from coming loose and damaging another engine part., like the oil pump or worse. |
I've been spending alot of time with my 86 454 and your picture labeled 454 4.jpg looks just like the oil return passage just in front of the #1 cylinder on my engine. I didn't think it was ok but seeing yours makes me feel better. I'm thinking it's just lazy GM not cleaning up casting waste. Good luck!
I have seen this many times it is normal.
You young guys are maybe spoiled by the casting quality of modern vehicle parts. what you are showing is par for the course in the old days, the factory rarely ever cleaned up castings. Areas were either as-cast or machined, no hand blending or deburring of any cast surfaces.
454 Project.
Wow, that makes me feel better, I will grind the flashing down and lay that one to rest. I am pretty particular about my stuff so maybe I just worried too much. Thanks Guys. Saved me a lot of time and $$$$$$$.
I cleaned up the flash inside the water ports in my heads while I had them off during my rebuild. I looked for some pics but cant find any of the flash I removed, It only took a few minutes while I was rebuilding the heads. Last edited by muddi1; 08-23-2010 at 09:47 PM. Reason: spelling |
The oil drain back slots in the lifter valley also probably have casting flash around the edges.You may as well clean that up while you have your Dremel tool out,heres a picture of mine;
![]() I polished the valley at the time,some people pain it with Glyptol or Rustoleum.its thought that either way will help with oil drainback. Guy |
You don't need to do anything- all the "issues" are non-issues, as has been said. Unless you disassemble the engine, leave the deburring until next time- you do not want to attempt to grind metal on an assembled engine.
I did all mine while dis aasembled, I would never suggest doing anything while assembled. I deburred everything including the leading edges of the crank to help with windage. I figured "since I was there"
I wouldnt have done any of it had I not rebuilt. |
454
On that note, I'll button everything up and drop her back in. I have plans to run her out to a 496 in the future so I'll take care of the flashing then. I was also planning on smoothing out the flashing on the outside of the block too. That should be some project!
I did my block and heads, I tink i'm going to do the water pump too, I used 1200deg primer (2 coats sanded between each coat and 2 coats of 900deg engine enamel) heres a look..I also redid the timing cover,pan, and valve covers after bead blasting them..
| new project looking for advice | 71corvette | Hotrodding Basics | 19 | 12-30-2007 09:23 PM |
| new member need advice for chevell project | Pablo Cusa | Introduce Yourself | 1 | 07-09-2007 06:25 PM |
| paint prep advice request for toy car project | pigjamelectric | Hotrodders' Lounge | 1 | 01-08-2005 06:00 PM |
| paint prep advice request for toy car project | pigjamelectric | Body - Exterior | 2 | 01-07-2005 03:54 PM |
| 454 buildup; not happy- need advice, suggestions, etc!!! | Bob Turner | Engine | 14 | 11-25-2004 08:00 PM |
