454 Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2012, 09:01 PM
454 Question
I just brought this rebuilt 454 and this is what I am working with
Block # 361959P, C23 76, T1104TSD, E5, T14, 2 Bolt
Crank # N353039, H126, N1
Block: Wet-mag(OK), Bored.030, align-honed, square decked, moly honed(+.0005)
Rods: OEM, wet-mag(OK), resized, new bolts
Crank: Wet-mag(OK), Index grind, .010-.010
Any ideas on where I should go next with it. I am trying to be between 400-500hp.
Old 04-04-2012, 11:17 PM
68NovaSS's Avatar
Wiki Edits: 9
Why don't you try doing a search here, there are builds up the ying yang in the database. Moving to Basic.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 04-04-2012, 11:22 PM
where exactly are they showing the motors being rebuilt?
Old 04-05-2012, 04:47 AM
400smb_s10's Avatar
Back Yard Junky :)
Location: Around the Corner from the middle of nowhere... Arden Ontario
here are some links that i dug up for ya
http://www.carcraft.com/techarticles.../photo_02.html
http://www.superchevy.com/technical/...d/viewall.html
Old 04-05-2012, 04:55 PM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
That crank "cast Iron"? ...And the "new" studs on the rods, they new "after-the-market" or new "stock" GM?
Old 04-05-2012, 05:36 PM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
whats it going to be put into? , how will it be used? , what is the rest of the drivetrain?
454 cam question truckboy61 Engine 4 11-11-2010 03:19 PM
454 question? BigBlockT Engine 20 01-22-2009 03:08 PM
454 question boatanchors Engine 10 08-31-2008 12:43 PM
454 question dboyett Engine 13 11-29-2006 08:55 PM
454 with suspension question on my 72 72 Z28 Suspension - Brakes - Steering 2 12-14-2002 03:10 PM
