well i haven't bought the cam yet that's just what I'm looking at...
however with a 4.25'' stroke crank and 6.385'' rods and 115cc heads and these pistons
http://www.jegs.com/i/KB-Performance...7.030/10002/-1 my compression should be around 9.9-1 +/- not sure yet how much the machine shop will have to remove to deck the block but I was thinking and correct me if I'm wrong but with the dome top piston and the longer stroke if I run the bigger lift cam, I run more risk of slapping a valve with a piston. I might be wrong but I was asking for advice on the cam because there are alot of people on here that know alot more than I do. and I would much rather do it right the first time... That said I am open to suggestions and do need to order my pistons quickly so I can get them to the machine shop before they do the final hone on the block so if i should need bigger or smaller pistons I need input by Friday morning..
thanks James
