454 rebuild wont stay running - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2010, 07:41 PM
Got my 454 BBC started and broke in. Changed the oil and filter and have driven it about 130 or so miles. It has been running rich but i didnt see a problem with it running rich, better than lean until i can spend more time fiddling with the carb. I started it yesterday and pulled it out of the garage to wash the car.
I washed the car and tried to start the car, it started and ran for a few moments then died out. Would fire for a short period then die out. Then i think i flooded it because it just wouldnt start anymore. Pulled the plugs and they were wet with fuel, wiped them off and tried again, got it to fire for a short period then died. Figured i'd go buy new plugs and try again today. Put them in and fired up the car for about 10 seconds or so and it just dies out. Started fiddling with the carb and checking my fuel line and making sure there was plenty of fuel in the bowls.
The motor is obviously a 454
BG 850 Silver claw DP carb
10:1 CR
hyd flat tappet 230/230 @ .050 (280H comp cam)
Mallory Hyfire sportsman VIIs
Brand new coil/module/cap/rotor
plugs are a few years old and one was burned through on the header a bit but has never cause any issues. I have new ones on order.
Ideas?
Old 03-16-2010, 07:45 PM
Show me the money !
I'm no expert, but when that happened to me, there was a choke issue.
Old 03-16-2010, 08:07 PM
im running without a choke and and wasnt having this issue any other time i've previously started the car.
The fuel pressure is up at like 9psi when the car isnt running and soon as it starts it drops to about 6psi. If i try and blip the throttle a bit it responds then dies. Every now and then it will spit a bunch of fuel out the top of the carb.
Now that im thinking about it there have been a couple of days i've gone into the garage and there is fuel sitting ontop of my intake where its leaked out of the throttle body of the carb...
Do i need to readjust the valve lash after the intial break in? Maybe im not getting enough air into the cylinder? Spark has to be good. Carb may be bad? My car sat in a storage unit for about 3 years without being run and this carb was on the old motor. Since i've got it back in my garage i put a new motor in and everything else is new/checked/reconditioned/replaced EXCEPT the carb.
New retiree w/motorhome and 454 rebuild jack0034 Hotrodding Basics 2 02-13-2010 09:44 PM
454 rough running truckboy61 Engine 1 01-19-2010 03:56 PM
Engine wont stay running. eric32 Engine 24 10-19-2009 05:40 PM
chevy 383 stroker starts but wont stay running the specks for the most part are here pealjoints Engine 3 08-06-2009 05:26 PM
Engine won't stay running - maybe VATS? chevy_c10 Engine 33 07-30-2009 05:24 PM
