454 spark plug recommendation - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2011, 04:17 PM
truckboy61's Avatar
Best plugs for my combo 454 30 over , 206 closed chamber heads from a 65-66 396 , comp cam grind #cb 294s-10 solid litters, Holley 4150 (9188)
Old 05-28-2011, 04:24 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Just go to any auto parts house website and plug in your engine. From the stock plug listing you can go up or down with heat range until you get the reading you like, all motors will be a little different.
Semper Fi
Old 05-28-2011, 04:31 PM
truckboy61's Avatar
To be honest I have no idea what to look for ? What factors to consider? Any advice would be appreciated.
Old 05-28-2011, 05:31 PM
truckboy61's Avatar
Would I make a choice based on my mid 70's 454 block or 1965 396 heads ?
Old 05-28-2011, 05:40 PM
ericnova72's Avatar
More for Less Racer
The '65 396 heads will take the big 13/16" hex size plugs. The mid 70's 454 application would take 5/8" hex "peanut" plugs which won't fit the early 396 heads.
R44 would be the AC Delco number, possibly R43 if you need a cooler plug.
Spark plug recommendation needed Zeeb Engine 1 09-04-2010 10:58 PM
spark plug recommendation ? vetteran Engine 2 07-25-2010 06:56 PM
Spark Plug recommendation BigLeoRocks Engine 3 06-13-2010 01:04 AM
Spark plug recommendation sanman Engine 1 04-21-2008 11:30 AM
Spark plug recommendation for 6-71 SBC XNTRCI-T Engine 4 04-11-2006 10:20 AM
