Hotrodders Bulletin Board
#1
454 street engine ??s
454, std. bore
powerforged pistons just over 9:1 compression 781 heads, stock valves, 3 angle valve job, pocket ported lunati voodoo 256/262 cam proform 1.7 ratio roller rockers 670 street avenger performer rpm intake any clues on power numbers??? and any advantages to swapping to a 750cfm speed demon?? |
#2
re: 454 street engine ??s
I'd guess around 375-390 H.P. if you have 1 3/4" primary headers and a properly curved ignition system. The larger carb may give slightly higher 'peak' HP numbers, but the carb you have now should give great drivability and accelleration.
#3
Big limiting factor (the stock valves)... Open them up for the 2.19/.188 valves and it will breath a whole lot better... Also switching to the 750 speed demon with the larger valves will work great together... |
Back to top |
Similar Threads for: "454 street engine ??s"
| Port or Full time vacuum | cool rockin daddy | Engine | 31 | 04-03-2006 12:06 PM |
| 94 454 pickup engine rocker type? | macx | Engine | 1 | 06-21-2005 05:49 AM |
| Rebuilt Engine Squeaking, Driving me Nuts! | BH69Camaro | Engine | 24 | 04-22-2005 08:51 PM |
| New Engine Selection | HotRodMan | Engine | 2 | 07-03-2004 10:22 AM |
| 454 engine swap | joes stude | Engine | 1 | 07-17-2003 08:12 AM |
