454 swap to a 2007 8.1L - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2010, 07:39 PM
454 swap to a 8.1L
i have a 454 in my 95 C3500 dully wanting to know if the swap will be better. I have access to an 8.1L vortex out of a 2007 2500HD truck. the motor has low miles and has a blown head gasket. warranty people just put a new motor in the truck being it was under warranty. Instead of having to get a new computer and wiring harness for my truck to swap it, I was going to go the rout of getting rid of the fuel injection system and turning it over to a carb set up, putting a MSD ignition set up on it. But will my headers off my 454 interchange along with my transmission? I know the 8.1L takes an Allison transmission.
Old 09-17-2010, 02:22 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
A little info
Rich
http://forums.hotrod.com/70/6565505/...81l/index.html
Old 09-17-2010, 06:07 PM
bigdog7373's Avatar
Of course it's fast
The transmission should bolt up, but i'm not 100% sure. You will need either different headers or the 8.1 manifolds. The 454 heads and the ls engine heads are completely different and your current headers won't work. Running a carb and msd ignition control box is a good idea in my opinion, it simplifies the swap and it easier to work on. Good luck
Old 09-17-2010, 07:00 PM
BOBCRMAN@aol.com's Avatar
Also your front mount accessories will not directly bolt on. The 8.1 has no harmonic balancer. Just a serpentine belt pulley pressed onto the crank.
Only carb intakes are HIGH dollar units. No previous BBC intakes or heads will fit 8.1
Old 09-19-2010, 08:14 AM
454 swap to a 8.1L
ya i figured my headers wouldn't work. i get horrible gas mileage with my 454. i wanted to do a swap to hopefully help the truck out. the reason why i wanted to transfer the 8.1 to a carb. is because i want to avoid the wiring harness and the computer. i would probably have a hard time finding them and i know the dealer will want an arm and leg. when i read about the 8.1 i read that the newer 8.1 you cant transfer the motor to a carb. i believe i found a intake but it was $3,000.00. think its going to be a good idea to even do the swap. what will be the positive out come out of it besides a bigger stroke? thanks to all of you for your help
Engine Swap 350 to 454 Mikeamyj Engine 2 01-15-2007 11:04 AM
1981 blazer 454 swap aceofspades49c Engine 1 12-11-2006 03:34 PM
454 TBI Swap Junorr Engine 0 09-06-2004 03:58 PM
454 turned 396 swap crash Engine 3 04-06-2002 09:02 AM
