454 T-400 Questions. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2010, 12:06 AM
Rodillac's Avatar
Cadillac User
So I have a 78 Caddy with a 425 and (I think) a TH400 3 speed auto trans.
The trans shifts very nice, and I have no problems with it. The 425 has a HUGE amount of blowby, and just needs a full rebuild. I plan on making a mild rod out of this car, and would like to put some nice after market performance parts on it, and I can't really do that with the 425.
I found a dirt cheap 454 for sale that is in pretty good shape. It also needs a rebuild. I'd like to drop a 454 in the car for the ease of adding performance parts, since the parts are everywhere.
My question is, will the 454 bolt up to the TH400 without dropping out a year or two down the road? I know the TH400 is a beast of a trans from reading up on it, and have read in several places that they can handle 500HP without issues. (Which is probably the max I would want.)
This car will not be a drag car, but it might make a few runs down the strip in it's life just for fun. I'm building it for a cruiser, so it will rack up the miles pretty quickly. I just need to know if it will bolt up without issues later, and if it's even worth it to keep it.
Old 07-10-2010, 12:28 AM
Rodillac's Avatar
Cadillac User
Also, if I'm wrong on what trans I have, please let me know. Everything I've found says it's a TH400.
Old 07-10-2010, 07:42 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A BOP tranny can be easily bolted up to a Chevy engine like the 454 BBC. It takes an adapter plate like the one sold by TCI.
Old 07-10-2010, 07:51 AM
Rodillac's Avatar
Cadillac User
That's what I thought. I saw that on several forums, but I also saw that the tranny wouldn't last more than a year, as well as the rear end.
Now, I just need to figure out how to rebuild a BBC for super cheap. lol
Old 07-10-2010, 07:56 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
How long the trans and differential last is dependent on the weight of your throttle foot.
Old 07-10-2010, 07:57 AM
Rodillac's Avatar
Cadillac User
It gets pretty heavy at times, but normally it's average.
Old 07-10-2010, 08:47 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Your Cad may have a "corporate" 8.5" 10-bolt rear end (center, look for the squared-off "ears" on the bottom):
If so, it is a good, strong rear end. You may have either a 2.56:1 ratio (a "2-series" diff, if it IS a corporate 8.5") or a 3.08 ratio, which is the "3-series" carrier. The 3-series is preferred because it allows a wider choice in ratios of aftermarket ring and pinions to be used.
You have a TH400- there's no problem w/the strength there, although yours will likely have the less-desirable 71-up intermediate roller clutch instead of the smooth inner race direct drum sprag-type. But rebuilt w/quality components, it will work fine for your deal, IMHO.
Old 07-10-2010, 03:55 PM
Rodillac's Avatar
Cadillac User
I was planning on either having it rebuilt or rebuilding it myself. Might as well since the motor will be out anyhow.
Old 07-10-2010, 09:21 PM
TH400s came behind many many many 454s. They have no problems with them at all. I am using a 78 TH400 behind a 454 in my 79 C10 and it has never been rebuilt. It sat outside of the old 78 for a few years under a tarp out in the elements without the cooler lines being capped. I didnt realize that until I went to use it. Anyways its still working fine and its been behind two 454s now. Tough trans.
Old 07-12-2010, 02:12 PM
Rodillac's Avatar
Cadillac User
Did you put it on the 454 with the adapter plates, or no?
Old 07-12-2010, 02:18 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Speaking for myself, I've used the TCI adapter both to use a Chevy engine and a BOP transmission (both TH350 and TH400) as well as the other way around- a 455 Pontiac w/a Chevy short tailshaft TH400 in a Camaro. Worked fine.
Old 07-12-2010, 02:32 PM
Rodillac's Avatar
Cadillac User
Sounds good to me, man.
a few 454 Questions getmoney06 Hotrodding Basics 43 07-08-2010 10:45 PM
350 to 400 HP from a 454...help John_H Engine 9 07-24-2009 01:17 PM
454 questions Lousdepot Engine 24 09-04-2006 10:07 AM
400 or 454 kool_mody Engine 10 09-05-2003 07:35 AM
454/400 turbo kevkoracing Engine 0 08-17-2003 02:14 AM
