Is this 454 a "tall block"?
Just picked up a 454 from a 1991 GMC 3500 truck; it has fuel injection. Will this be considered a "tall" or "standard" block? Also, will a carburetor manifold fit this engine? I really don't want the complexity of a fuel injected engine.....it's going in my '67 Chevelle Malibu.
Thanks in advance!! |
Should be a standard deck. And you can put a carb on it also.
Manifold/head replacement
Thanks guys! I'm hoping to pick up the engine this weekend. So I guess I can put any big block intake on it? Provided, the ports line up. I'm thinking of going with aftermarket heads; any suggestions? I'll be running a turbo 400, 3200 stall converter, 3.73 gears, in a full bodied '67 Chevelle. Intend on using it for street/bracket racing. Leaning towards aluminum big port heads to save some weight up front.
If its truly a 454, its not a tall deck. There were no factory 454 tall decks, only 366 and 427, and only in medium duty and up. Busses, dump trucks, step vans, etc. All the light duty trucks up to 1-ton got standard deck engines.
Putting a tin big port head atop that combo would be a step backward even with the 75 lbs weight reduction. A healthy 454 on the street usually has a 10/1 static cr..a camshaft with mid .500 lift,230ish* of duration @ .050" on a 110 lsa with oval port heads cleaned up. Leave the rectangular ports on the shelf unless you have 500 cid or a 7k high winding 427. The rovals that Eddy offers are a nice balance with the 110 cc chamber.Would raise your static cr and maintain good port velocity at lower rpm,s.Of course you will be changing the cam that compliments the heads and retains some semblance of effective cyl pressure. |
| replacing a 454 with a 350...... | Treozen | Engine | 8 | 03-05-2008 01:28 PM |
| 5.0 to 7.4 swap | Tilar | Engine | 7 | 02-09-2008 06:51 PM |
| 454 into 427 | Alan Byers | Engine | 22 | 01-18-2008 12:36 PM |
| Squeezing a little more power out of my 454 | RObs71Nova | Engine | 8 | 05-21-2005 03:38 PM |
| 454 or 427 for 70 Chevelle? | f100beatertruck | Engine | 3 | 11-25-2003 05:29 PM |
