Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 Tall deck??????
Old 07-30-2002, 02:39 AM
The Vandal's Avatar
The Vandal The Vandal is offline
Engine Tech Addict
Post
The pushrods are also longer.........and as far as not being good blocks - they give you the opportunity to use a longer rod or use a longer stroke and still have a decent rod/stroke ratio. Because the decks are higher, the heads are further apart so a manfold made for tall deck (or spacers) must be used. You also must use a distributor for tall deck or one with an adjustable coller.
The Vandal
