454 TBI wont stay running. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2010, 07:52 PM
I am working on a 1987 Chevy 1-ton that has the 454 with TBI. I can start it and it will run anywhere from 10 seconds to 2mins, it studers then will idle up and down before it just stops. This morning I changed the Fuel filter on the passenger side rail. (NO JOY) I can hear the Fuel pump priming and it sounds fine. I took the Air intake filter dish and cover off and can watch the fuel come out of what I believe to be the injector nozzles, it flows very well and does not sputter and appears to be working fine. At that point I ruled out the fuel system and I have moved on to the ignition system, after verifying the plug wires were correct we pulled the cap and looked at the rotor button it was pretty rough so I replaced that and the cap as it was really rough (corrosion on the studs) while in the distributor I replaced the ignition module as well. I reassembled and re verified the wires to the right place, again no joy. So now I am at a loss. I know that the ECM plays a big part in the ignition and fuel setup however I am not sure which of the 7 or 8 data parts it controls to look at. I am getting 14.75 volts output at the ALT. and 13.75 from the Batt. The plug wires were replaced about 2 years ago and ohm out fine. Any help would be great.
Thanks
Walt
Old 06-20-2010, 11:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Have you watched the fuel flow from the injectors as the engine falters then quits? Because it sounds like it's running out of fuel to me.
Check the injector flow as best you can as the engine dies, and also retrieve the codes as a place to start. Could be as simple as a pump relay.
Old 06-22-2010, 03:45 AM
68ss's Avatar
jackleg
Walt,
have you taken a look at the fuel flow yet?
Toby?
TBI engine swap, 305 to a 454???? gofastz Engine 7 06-22-2010 04:49 PM
454 running problems lt1_performance Engine 13 05-10-2010 08:06 AM
chevy 383 stroker starts but wont stay running the specks for the most part are here pealjoints Engine 3 08-06-2009 05:26 PM
Engine won't stay running - maybe VATS? chevy_c10 Engine 33 07-30-2009 05:24 PM
intermittent stumble, '91 454 TBI dastone Engine 2 01-22-2006 03:08 AM
