Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 ticking
Thread: 454 ticking
Old 04-29-2013, 10:10 AM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
Short of checking the obvious, collapsed lifter or flat lobe, I don't have an answer, but lean toward a bad lifter. Was it ticking before rebuild? Perhaps there's a restriction in the pushrod body or oil passage to that lifter. You have good oil pressure? Have you run it with the valve cover off, (with oil restrictor clips), to see if it's oiling?
Semper Fi
