454 ticking - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2013, 09:16 AM
Chev85's Avatar
454 ticking
I recently put in a freshly rebuilt 454 into my k10
The lifters were making some noise so I went through the process and loosened till they ticked and then tightened 1/4 turn.
I did this process 3 times but I still have a tick inside the motor somewhere that was not there originally.
Old 04-29-2013, 09:55 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
In the 454's early days GM had an inherent issue with valve train noise. My brother bought a brand new 1974 454 Suburban with the same problem from day one, the dealership never did figure it out. Fortunately for him he was half deaf from a Vietnam GSW, he was good with it.
I have a tick in my BBC T-Bucket, currently changing over to a roller setup, curious to see if it goes away. I originally thought it was a roller rocker hitting the VC on the top side, but not so sure after grinding additional clearances and not seeing any new witness marks. I'll find out if it's an oiling issue when I fire it up.
Semper Fi
Old 04-29-2013, 10:03 AM
Chev85's Avatar
So what do you suggest I do?
Old 04-29-2013, 10:10 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Short of checking the obvious, collapsed lifter or flat lobe, I don't have an answer, but lean toward a bad lifter. Was it ticking before rebuild? Perhaps there's a restriction in the pushrod body or oil passage to that lifter. You have good oil pressure? Have you run it with the valve cover off, (with oil restrictor clips), to see if it's oiling?
Semper Fi
Old 04-29-2013, 10:21 AM
Chev85's Avatar
It originally did not click but my lifters according to my mechanic were not tightened correct so I cut holes into my old valve covers and had the engine running at idle. After going through the process I heard a loud tick that went with the engine no lags. I gave it gas it accelerated the click continuously. Oil pressure was just above 30.
Temp of engine was roughly 190-200
1974 454 ticking sound Torque454 Engine 7 02-28-2011 04:09 PM
454 ticking about to light a match Twistedwrench Engine 40 02-12-2011 04:34 PM
454 Ticking noise - Lifters or valves? Torque454 Engine 13 11-30-2010 08:50 AM
ticking truck52 Engine 3 12-03-2008 09:42 AM
Is it just me - Ticking ...... ??? Tomard Engine 18 10-13-2008 02:56 PM
