454 Timing marks - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2010, 03:16 AM
muddi1's Avatar
454 Timing marks
Ok, I am about a day from firing my newly rebuilt 454 and I am second geussing myself on the proper timing mark placement....I would likek to be positive I have done it correctly now so that if I do have to fix it its alot easier and not death to my new engine.
I installed the new timing set as described in the compcams guide...
http://www.compcams.com/Technical/In.../Files/172.pdf
I have read that with #1 at TDC the marks should be at 12 o'clock....the guide says 12 and 6....so which is it?
Thanks
Old 09-08-2010, 05:41 AM
DoubleVision's Avatar
Cam at 6 o`clock, crank at 12 o`clock.
Chevy SBC, finding TDC without timing marks 04SilveradoMykk Engine 2 10-25-2009 06:11 PM
454 timing issue Fastest65 Engine 3 07-27-2009 01:44 PM
351W Timing marks & 408 clearance question eric866121 Engine 5 07-05-2009 02:51 PM
454 Ignition Timing Question leejoy Engine 56 09-13-2008 08:40 AM
timing gear marks Blob Engine 1 04-06-2004 09:08 PM
