How easy does a 454 drop in a 60-63 c10 and what are the biggest tire/wheel combo you can cram under the back of a fleetside and the biggest for a stepside. THanks
if you go to chevytalk.com and scroll done to the 60-66 truck form there are some guys that can help you out. I'm putting a 454 in my 66 C10 and as far as i've read it will bolt in using the 6 cylinder motor mount holes and then depending on what tranny setup your going to do your have to tackle that also. Not sure about the wheels. The biggest issue is the headers Sanderson's block hugger is what I've found to be the ones that will work.
Thom
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
