454 umbrella valve seals - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2013, 12:00 PM
ss396si's Avatar
This is my first build. I have a 454 w/781 heads and dual valve springs .im having a problem installing valve seals. Now I slide on the umbrella valve seal( comp cam 504-16) for the intake valve. It fits on nice and tight but the base of the seal does not reach the base of the retainer. Where the spring sit. Is this normal?
Old 04-23-2013, 03:23 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I don't see the seal in your picture, what am I missing?
Semper Fi
Old 04-23-2013, 03:26 PM
ss396si's Avatar
I didnt take a pic of it with a new seal. The seal looked to short like it wasnt reaching the seat. Would the umbrella seal be fine over the valve stem?
Old 04-23-2013, 04:23 PM
Umbrella seals are not so much a seal as a shield that rides on the valve stem to deflect oil away from the stem and upper guide. It is not intended to cover nor attach to the upper guide. See first attached picture.
Items that actually make a seal between the stem and guide require the guide OD be machined to a specific diameter, they then slide down that machined surface and are friction retained by a metal clamping device. The stem fits through the seal which wipes the stem but does not ride with it.
See second attached picture.
Bogie
Old 04-23-2013, 04:40 PM
ss396si's Avatar
Bogie
Thank you, all I have to do is slide the seal on the valve stem down to it stops at the upper guide.
valve seals.. E.Furgal Engine 4 10-20-2012 11:26 AM
Umbrella type valve seals Torque454 Engine 11 02-07-2009 08:48 PM
Umbrella and viton seals on pre 1981 chevy small block? bowtie6 Engine 6 05-25-2008 04:50 PM
Umbrella Seal Clearance inside Valve Spring dirtydave Engine 3 08-28-2007 07:17 PM
Can the dual coil valve springs on a BB destroy Valve guide seals Auto-Part Engine 4 11-25-2003 06:23 PM
