454 valve covers w/rollers - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2006, 09:47 AM
New Member
Anyone know of a valve cover that will fit BB chev. with Edelbrock heads and Harland Sharp 1.7 rollers without having to grind edge of rocker??
Thanks -- Rick
Old 06-13-2006, 12:14 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
There are hundreds. summitracing.com jegs.com gm parts counter, local auto parts store, swap meet.
Just get some taller BBC valve covers. Stamped steel chromies should cost about $35. Swap meet polished cast aluminum ones can be had for $65. You DON'T want to grind on rockers.
Old 06-13-2006, 02:32 PM
New Member
Thanks for your reply but, the height is not the problem. The h/s rockers come very close to the valve cover rail on the upper part of head, with one on each head being right by the bolt holes.
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 01:49 PM
center bolt valve covers jesse01 Engine 10 02-18-2005 08:50 PM
small block Ford valve covers Da' Bomb Engine 0 09-11-2004 08:44 PM
Re: Roller Rockers, Stud Girdle - Which Valve Covers? jerseyjeff Engine 5 11-07-2003 06:07 AM
