454 weiand 177 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2011, 05:34 AM
454 weiand 177
What if I used the weiand 177? I could zero deck and use flat tops and my 820s (with bigger valves), that would give me around a 8.5:1 CR. I have read somewhere that the coolest design is a dished piston.. If I ran a supercharger I could drop the CR way down and add boost couldn't I? Would I use a special cam for forced induction? What would that do for power? I have done a little bit of reading but its hard to find people using the smaller ones..
It appears as if this is a good mild supercharger..
Otherwise considering scrapping the 820s (would like to use em though) and purchasing some AFR 265 CNC. Was gonna use a XR288HR cam and 9.7:1 CR. Problem seems to be finding a piston, not sure if they're open or closed chamber heads. The sealed power speed pro -13.80cc dome (.095") are listed for open chambers in jegs..
Old 01-22-2011, 07:04 PM
So the flat tops would be better? I had considered using the D shaped cup pistons because I read somewhere they helped with quench or detonation or something.. Not a good idea? Woulda been 8.2:1 with d cupped ones or 8.5:1 for flat tops.
I was noticing they used 112-116 lsa cams. So Hyd Roller be not such a good idea for a blower street use? I'm looking for torque everywhere and good power for the street. Don't wanna go over 6000 RPM.
I found some reading material online from weiand and read most of it so far. From what I understand a 12:1 "effective" CR is ideal for 92 octane. So then a 11:1ish for 90? Thats 4 - 5 psi boost with a 8.5:1 CR (2:1 underdrive).
I planned on doing some minor porting to my 820s (open chambers). Just gonna smooth a few ridges and a bowl blend. They just have such an odd size chamber that its too small for a dome piston and too big for a flat top (my opinion). So now I'm wondering about getting a little "pocket blower" so it will fit under my hood (77 stepside C10).
Old 01-22-2011, 07:14 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You could use more information on the basics of supercharging, I highly recommend reading Street Supercharging by Pat Gahnal. That would put you on the road to a decision and give you some real insight into supercharging.
Also, use the search function here, supercharging has been beaten to death, there's a wealth of information on this board.
weiand 250 on BB? Roald Engine 2 11-17-2009 05:55 PM
weiand 177 vs 250 Roald Engine 10 06-02-2009 01:59 PM
more weiand 144 ?'s cochino12 Engine 5 11-16-2008 12:53 PM
Weiand Stealth and Weiand XCELerator intake manifolds...best one?? TheZaZ Engine 5 09-08-2006 07:25 AM
weiand intake qs darom Engine 3 08-23-2005 12:57 PM
