455 Firebird - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 03-05-2006, 06:07 PM
Chief-Pontiyacker
455 Firebird
Hello all, my name is Jason and Im currently working on a 68 Firebird , main reason for checking out as many forums as possible. Here is a link to the little bit of non-exciting work I have done to the Firebird. http://community.webshots.com/user/murphs314
Im in the military (USAF) for 14 years now, thats why if you go to the link youll see two folders with pics of the car adn a folder with pics of my friends at Metal Masters who are doing the body work right now.
Currently I have, as I said, a 455, (standard bore) with a hot street cam that gives me .503/.520 lift with 1.65 rockers. The heads were donated from an old pontiac 400 and are 4X-7H heads modified with stainless steel 2.11/1.77 valves. The heads were shaved .20 to raise the compression from 8.8-1 to 9.4-1. The carb is a rebuilt 750 cfm rochester that was modified to flow 800cfm. Oh and for the neat little add-ons I have ceramic coated HOOKER headers with 1-3/4 inch primaries and I added March under-drive pulleys to the crank, watepum, alternator and power-steering pump.
For the front suspension I did the front drum to disc conversion adn am fixing to do the rear as soon as the guys are done with the body work. but they are just stock replacements for now. Im also about to order a new GM 12 bolt rear for the bird adn get the lowering leaf-springs for the rear and upper A-arms and lowering springs for the front, all from global west. Later Ill go for the lower A-ars and coil-over shocks.
Ill fill in more about whats being done with the body in a while, but for now, Ill see all of you in the forums and if I can help with anything let me know.
Bulldog
Old 03-05-2006, 06:41 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders, we are glad to have you here. Enjoy the site.
Will An Olds 455 Engine Fit In My 69 Firebird daveh Engine 5 11-11-2005 01:38 AM
the olds 455 in my 80 firebird bandit1 Engine 6 12-30-2003 07:56 AM
Putting an olds 455 in 69 firebird? rjrj4 General Rodding Tech 7 12-29-2003 04:32 AM
69 firebird with olds 455? rjrj4 Engine 8 12-18-2003 12:48 AM
455 vs 500? Wmarden Engine 7 10-26-2002 06:47 AM
