455 olds block - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2010, 01:20 PM
2ndchanceauto's Avatar
body and paint guy
Last journal entry: delivered
455 olds block
anyone know where i can source a olds 455 for my cutlass. want to swap the 350 rocket for the 455 but blocks are hard to find. built or not it doesn't matter.
Name:	my cutlass.jpg
Old 08-15-2010, 02:07 PM
artsvettes's Avatar
Craiglist Central New Jersey listed today
Old 08-15-2010, 04:40 PM
sqzbox's Avatar
My pipes are my music
DUDE! If that's the car your talking about, why not hop up the 350 and keep it #'s matching? A beutiful car like that is worth it's weight in gold in original form. That's really a nice ride man! I'm having to put a scott towel on my keyboard right now to keep the drool off it!
Old 08-15-2010, 05:22 PM
I find them all the time on Craigslist here in the Washington DC area. I buy any one I can find at $150 or less for a short block core. Use a site like Searchtempest or similar services to search all Craigslist sites within a specified distance from your location. Also, consider that a rusted-out Olds full size with a 455 can usually be bought for less than the cost of the motor.
Old 08-16-2010, 05:30 PM
body and paint guy
the car is only a cutlass S bench seat 350 2bbl car. i have converted it to a factory 4bbl. with an HEI. its alittle anemic and would love to put a big block in it. not to mention i am looking for a modle A or duce I can put the rocket in after i rebuild it. my intention is to make it a 442 clone. buckets console and drivetrain, but put 4wheel disc and upgrade the handling.thanks for the complement i built this for my father before he passed away and just want it to snap your neck when you push the fun pedal.
Old 08-16-2010, 05:32 PM
body and paint guy
i'll have to widen my search i guess
Old 08-16-2010, 10:31 PM
NWayne's Avatar
Might give 442.com a try...
Old 08-17-2010, 09:26 AM
I have a '72 'S' that I'm doing the same swap in. I bought the drive train etc. from a '76 Delta 88. I already converted the bench to buckets and put in the console.
The engine has been torn apart and sent to the machine shop and for something that sat for 6+ years it looks good. The engine started before I bought it....a little gas in the carb, a strong battery and she fired right up. I paid $800.00 for engine, tranny (T400), rearend and rad. A strong price for sure but that was loaded onto my trailer.....seller pulled it and used his front end loader to lift it onto the trailer.....I just drove and handed over money. :-).
I haven't picked the parts yet so please keep me (us) posted as to what you go with. I'm leaning towards Mondello heads and intake but can't get any feedback on them from anyone who has actually used them in the last few years. Eddelbrock is always a good source so they may get the money in the end.
I have posted a few pic's of my ride on here "somewhere" but don't really know where they ended up. Mine is green with gold pearl and a white interior.
Old 08-17-2010, 10:02 AM
Keep the Olds 350, properly built its more than enough engine. Last one I did came in under $2500 for a pretty nice engine and it pulls like a train.
Old 08-17-2010, 10:16 AM
The rocket 350 came in various "disguises". Out of the box, mine was a 195hp +/-. I put the 4 barrel on, I did the dual exhaust and I bought the headers. Not installed but that's another story. :-)
Bottom line is it's a dog. This may be why they were called gutless cutlass when I was younger. Tuned to the nines and running well mine tops out at about 110mph. My buddies warmed up 350 Monte Carlo shifts into 3rd at 110!!!
Like the old adage goes, there is no replacement for displacement. My 350 will be warmed up and ready to go back in or will find a new home. As pretty as these cars are, they will never bring Chevelle type money in the market so keeping it #'s matching is no big deal IMHO. Period correct is close enough to me. '72 is the year I got my license and if I could have afforded one of these then, it would have had the 455 or I would have dropped one it then too.
Old 08-17-2010, 10:33 AM
My "gutlass cutlass" will cruise at 125 all day long... The Olds 350 is a MUCH better design than the SBC, only problem is parts availability
Properly done the 350 can do VERY well, put it needs more than just slapping on whatever parts were on sale that week. 500hp with modified factory heads is doable. You can do that with the 455 too, you'll just spend a little more in the long run, but the 455 will have more torque.
And depending on what you have and what you compare it to the Cutlass can do better than "chevelle type money." So many people underestimate the BOP's.
the 455 is not a bad engine at all, it's just not needed to go fast. What is needed is an intelligent build from the ground up.
Old 08-17-2010, 10:34 AM
Standard gearing in most 70-72 Cutlass was 2.56, thats a big reason that theyre kinda doggy in stock form. Even if you build the engine and leave the converter and rear gears stock, youve missed the most important part of building a quicker car.
Before you waste your money on anything from Mondello, check the 'net for refrences. Mondello has a very poor customer service rating and is generally overpriced. Plenty of places you can get the same parts for less.
Unless youre trying to build a 10 sec race car, then Edelbrock or reworked factory heads with larger valves will be more than enough for a torque monster.
Build for low end torque and you'll be very happy.
Old 08-17-2010, 11:35 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
To play the devil's advocate for a minute- there's plenty of potential in the 350. Put some #5 heads fitted w/the 2" x 1.625" valves w/some porting of the bowl, etc.
A cam and the head work along w/a good high rise intake and a single 4-bbl. carb (think Q-jet) and a good exhaust system will put you right where you want to be. Obviously the rear gears and torque converter has to be optimized as well.
I love it when I read how the Olds 350 is such an awesome 'torque monster', pulls like a freight train, etc. The fact of the matter is, the bore and stroke is more oversquare than a Chevy 350! The 350 needs to REV, not poke around at low RPM!
The 330 Olds crank was steel, if you can find one. You will want to get better rods if you can swing it, otherwise ARP hardware and resized at a minimum.
Be aware that not just the 403 main webs were windowed. '77-up 350's (except the diesel) were, too.
There is plenty more to it than just this- I do not pretend to be an expert on the Olds. But I have built a 455 for a V6-equipped Cutlass (went easy 13's w/a 2.73 peg leg rear end, engine basically stock except a mild cam, fresh pistons, etc. from a wagon), and built another 350 for a buddy and refreshing a third 350 Olds top end. The results were all good.
Old 08-17-2010, 06:56 PM
body and paint guy
i have never had a big block in any of the cars i have ever built. Its time, since i don't feel the need to got over 125 mph i am really looking for the low end torque of a big block. I will have to say that in my area the cutlass gets ALOT of attention everyone has a chevelle or camaro ect.. the gto's, cutlass's, and gtx's done right get alot of recognition at shows. I guess i should clearify i don't want to build a 4-4-2 clone just want the parts i like and put in my car. i don't care about resale, this car will never be sold by me.that rocket would look awsome in a street rod though something different than an ls1
Old 08-17-2010, 08:30 PM
Sorry guys, but the 455 Olds only weighs about 40-50 lbs more than the 350. Why WOULDN'T you want an extra 105 cu in?
Olds 455 or pontiac 400/400 handymann3 Engine 48 02-03-2010 03:59 PM
455 Olds timing marks 71cutlass0159 Engine 6 01-26-2007 06:59 AM
olds 455 timing ? hotrodder442 Engine 4 06-25-2004 10:46 AM
455 olds engine..hot number 57chevymike Engine 8 11-26-2003 05:57 PM
stroker 455 olds 442 chevy power Engine 1 01-04-2003 05:26 PM
