455 Olds Engine into 56 GMC - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2013, 05:30 PM
Car Nut
The title is the question - - Will a 455 ci Olds engine fit in a 56 GMC truck?
Also, which gm overdrive transmission will best fit behind the 455?
Thanks, David
Old 05-03-2013, 06:38 PM
vinniekq2's Avatar
The Pontiac guys will love ya for the swap.I would contact TCI about their 6 speed auto and dimensions
Old 05-03-2013, 06:46 PM
Banned
that trans is a 4l80e
may need a hammer to make it fit as it's bigger than a th400
Old 05-03-2013, 07:20 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Do you already have a 455? The jimmy trucks like yours were available with first gen Olds V8's in heavy duty applications. As much as I like the 455 (I'm putting a 455 Olds in my 65 C10) I think a 394 would look killer under the hood and get the job done power-wise.
Old 05-04-2013, 12:53 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Would the later model trans' from GM still require the BOP bolt pattern for that motor?
Semper Fi
Old 05-04-2013, 05:09 AM
Banned
yup need adapter..
Old 05-04-2013, 12:06 PM
The TCI "six speed" is really a 4L80E. TCI changes the software to engage the OD clutch pack between normal gear shifts, splitting the lower gears. Two concerns.
First, the 4L80E OD clutch pack has only two plates. It's very easy to break. DO NOT ask me how I know this...
Second, why does an engine with 500 ft-lbs stock need additional gear ratios in between first and second, and second and third? Kind of a waste of money, in my opinion.
Old 05-04-2013, 12:07 PM
Car Nut
Thanks everyone for the quick info. I do have the 455, it has been kept 30 yrs on an engine stand, run every month or so. .... 43,000 miles.
engine 1970 455 olds 56oldsmobile88 Hotrodding Basics 1 12-30-2011 04:38 AM
Olds 455 Engine Swap To GMC Truck Crash2320 Introduce Yourself 1 05-15-2011 08:09 AM
olds 455 engine #s? 7thson69 Engine 4 07-04-2009 11:29 AM
help with 455 olds marine engine 442 chevy power Engine 1 01-03-2003 06:59 PM
350 or 455 olds engine? franny Engine 2 11-29-2002 09:32 AM
