455 olds oil blowby - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2011, 01:23 PM
455 olds oil blowby
Hi..I have a built 455 olds motor in a jetboat. Just got it.the motor was just rebuilt.has all good stuff that I can tell.hi rise intake 2 hollys. looks like original valve covers with pcv and push in oil cap. At speed it pushes oil out breather.not too good on hot headers.have been told rings need 2 seal.does this motor need pcv system?
Old 09-11-2011, 02:16 PM
mud.man.rj's Avatar
Pull a valve cover and see if the push in breathers are shielded as in some cases I have seen the rocker arm in area will spray right at bottom of breather and out the breather on to the v. cover. If shielded then definitely ring seal, just needs hours of run time or vented ststem to recovery tank.
Blowby Crispies 123pugsy Engine 3 04-27-2011 05:21 PM
Oil blowby/oil burning waltnardo Engine 7 03-24-2008 10:43 PM
Ford C3 Blowby ?? Theresa Shank Transmission - Rearend 3 09-26-2006 06:18 PM
blowby ram440 Engine 2 08-05-2006 04:07 PM
Blowby Problem Arrowhead Engine 6 09-23-2005 06:16 AM
