Yea it's true click on the link and scroll down and read this it will help. http://www.nastyz28.com/2gcog/rearaxle.html . Cole
It's true that, from the factory, a carrier for a 4.56 and a 3.73 were the same, but there are gearsets available for the higher geared carriers, too.
They make the ring gear thicker to locate it in the right place when used on a carrier for higher gear ratios. I would suggest that you verify which carrier you have before you order the new ring & pinion. You might be in for a surprize, otherwise.
| 8.2 / 8.5 Carrier & Gear Swap?? | chevy2N | Transmission - Rearend | 1 | 05-25-2003 07:06 PM |
| 10-Bolt 8.2 Gear Swap?? | chevy2N | Transmission - Rearend | 1 | 05-22-2003 02:25 PM |
| rear end gear swap | Jared | Engine | 3 | 03-19-2003 08:46 PM |
| Anyone changed a carrier gear? | WayOutCat | Transmission - Rearend | 7 | 02-03-2003 08:02 PM |
| 8.5 GM 10 BOLT CARRIER SWAP, POSSIBLE?? | PURPLEOMEGA | Transmission - Rearend | 0 | 09-18-2002 03:04 AM |
