46 Chevy front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2012, 08:17 AM
46 Chevy front end
We have a 46 Chevy pick-up sitting on a 1977 C-10 frame which brings the front tires outside the front fenders. Without buying or making a new frame, which is the easiest/cheapest way to close up that front end?
Sub frame? Positive offset rims? Thanks!
Old 01-14-2012, 08:59 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
wheels
how far do they stick out?
what is the backspacing, and how wide?
are the wheels that are on it now?
Old 01-14-2012, 09:04 AM
They stick out about 1 1/4" from the fenders . The rims are 7-15s
Not sure of the backspacing . Will measure when I get to the shop.
Old 01-14-2012, 09:17 AM
& matts38chev
what is the bolt pattern?
5 on 5? if so that will make it tougher to find wheels
Old 01-14-2012, 09:32 AM
Yes, 5 on 5. Found a place that can make the rims we need but at 600 bucks each, trying to find a different way.
Old 01-14-2012, 09:42 AM
& matts38chev
here is a chart of vehicles with that pattern
the newer the car the more likely it will be what you want
the first one off of the top of my head would be the new jeep
they are bigger dia. also
Old 01-14-2012, 09:46 AM
thanks !!!
Old 01-14-2012, 09:57 AM
& matts38chev
the jeep wheels center hub hole may be too small
impala ss - would look good, but i dont know the backspacing
Old 01-15-2012, 05:23 PM
66 to 77 Toronado and Eldorado wheels have that bolt pattern, and about 2" more backspacing than Chevy truck wheels.
55 chevy front end tomthecomic Suspension - Brakes - Steering 3 07-28-2007 02:45 PM
Clip the front of a 59 Chevy pu with a 70 Camaro Front clip? Will it work? classicappraiser General Rodding Tech 6 10-16-2006 12:05 PM
36 chevy front end oldrodder43 Suspension - Brakes - Steering 2 10-09-2006 05:52 PM
64 Chevy Front End 64 C-10 Suspension - Brakes - Steering 4 07-31-2005 11:00 PM
51 Chevy front end Jamie Suspension - Brakes - Steering 2 11-21-2002 06:50 AM
