'46 Chevy Panel, door panels - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2006, 07:16 PM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
I'm still workin on my '46 Chevy Panel truck and getting closer and closer to being done. The question I've got now is on the inner door panels. I have the orginal ones and they are all metal and I still want to use them. I've got some material left over from the headliner, its foam backed. I would like to use it on the door panels also. They will attach with some nice looking screws that I've got and am going to make arm rests out of oak to be mounted on them. The window cranks have been removed and switches put in a center consoule I made. Will this work or should I use something else. Matching the color of the headliner will be hard to do thats why I'm looking at it this way.
Thanks
Old 09-02-2006, 07:30 PM
BOBCRMAN@aol.com's Avatar
Use some good trim cement 3M super trim adhesive etc. With some imagination you can have a good looking door panel.
I used to cover the window crank holes with the adhesive backed aluminum tape type material that is used on cheap fender/rust repairs. It hides the holes well and lasts.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
1937 chevy panel truck tread40 Body - Exterior 3 08-08-2006 03:27 AM
OUTER COWL PANEL (52 Chevy p/u) Blaster Body - Exterior 5 05-18-2005 08:04 PM
Chevy 350 Engine & Trans in a 46 Chevy Pickup Warner Engine 4 02-11-2005 04:44 PM
Metal shrinking with a torch.....57 Chevy qtr. panel pasadenahotrod Body - Exterior 5 02-26-2003 10:38 AM
