46 Coupe steering swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2008, 02:44 AM
Does anyone know of an easy steering box/column swap for a '46 Chevy Coupe? I'm keeping the original suspension; manual steering is okay, power would be nice... Only reason to replace the box is that it is worn out with alot of play in it.
Any ideas? Thanx
Old 12-23-2008, 04:21 AM
1947 Chevy Coupe
The easiest swap is to just replace the box with another. Kanter should have a new one and I have a used one in the free speech auction.
I think I remember people having success using a box from a Vega too.
Old 01-16-2009, 06:31 PM
For those that may be interested, I found a power steering conversion kit in The Filling Station that includes bracketing, pitman arm & instructions to mount a late model Saginaw 525 manual or 605 power steering box in 39-48 Chevy cars
http://www.parts123.com/parts123/yb....Z5Z5Z50000014x
Old 01-16-2009, 08:47 PM
1947 Chevy Coupe
I just read recently that the 605's have problems with leaks. Might be the cheap chinese knockoffs though.
Old 01-18-2009, 10:36 AM
Hey Bluesman, I know you're installing a MII suspension on your coupe. Does the original suspension come off fairly easy? If I can put together a low buck MII setup for my '46, I may go that route.
Thanks
Old 01-18-2009, 10:59 AM
1947 Chevy Coupe
The TCI IFS I have is a bolt on unit with some welding. The old stuff unbolts but if I wasn't trying to save it I would have used a sawzall on much of it.
I have heard of an IFS that is a complete bolt on but even if you don't have a welding machine, getting a mobile welder off of Craigslist or the yellow pages is cheap.
Re the steering column, any late model GM column should work. I have one from the S-10 I parted out.
Old 01-22-2009, 11:52 PM
C-10 replied to the following question on another thread. Thought it could be useful here. Not sure how you would mount the rack and pinion to the original crossmember though.
"is there a way I can incorporate a rack&pinion to that without having to go with the mustang II frt"
Without a doubt, yes. The only thing that would be tricky is the steering input shaft, since that is a rear-steer ti-rod setup. Your rack would be behind the crossmember which ideally that is what the rack would mount to.
If it were a power rack, there comes the pump and lines from the front of the engine too.
I have not done one on a Fleetline but I believe I could pull it off. Depending on your tenacity, you could too.
46 Caddy Power Steering & Brakes STRODDER Suspension - Brakes - Steering 2 11-14-2007 12:08 PM
Need help with Electronic steering for my '40 Ford coupe MichaelSporong Suspension - Brakes - Steering 3 10-27-2006 02:34 PM
Problem solved, '46 Panel Steering Bluepen Suspension - Brakes - Steering 2 01-20-2005 08:05 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-04-2003 12:20 AM
power steering rack and pinion swap Paco Suspension - Brakes - Steering 0 04-03-2002 07:56 PM
