Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 46 ford 2 door
Thread: 46 ford 2 door
Old 12-03-2012, 08:17 PM
timothale timothale is online now
Wiki Edits: 27
speedway part numbers
the speeddway part no for the engine to trans 7200392
the speeddway part no for the engine to frame motor mount 91618005. read their instructions. it tells which chevy flywheel to use , and speedwway has a whole assortment of clutches. you will probably need some new cushions and mabe more frame brackets..
since he plans on running with the flathead eventually I would put in a the chevy engine with T 5 5 speed transmission with the S 10 shifter, convert to an open drive line or newer rear end, then when the flathead is ready, adapt the flathead to the T 5, It's a newer all synchro trans stronger than the old fords, amd the T 5 has the overdrive gear ratios.
