Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 46 ford 2 door
Thread: 46 ford 2 door
  #19 (permalink)
Old 12-04-2012, 11:09 AM
boatbob2 boatbob2 is offline
boatbob2
48 ford transmission..........FORGET IT,first time you put the go pedal to the metal,you will be trying to find another trans,if youre going to go with a SBC Chevy,go with either a 350,400 or 700R4 trans (all are automatic) keep in mind that the X member that holds the trans mount,will have to be modified,OR,you will not be able to pull the trans without pulling the engine,cause the chevy trans,will fit partially into that X member..I have a 48 Ford coupe,and i had to modify mine...good luck...
