46 ford 2 door - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2012, 12:51 PM
46 ford 2 door
ok my dad has a 46 ford 2 door sedan? and he has a 350 chvy motor he wants to put in it and i wanna do it for him for christmas.. well me and my friends and brothers do.. we have plenty of time to do it. we just need to know what adapter to get, where to get it? how do we know what tranny it has? it had a flat head v8 in it he wants to rebuild in the mean time of driving it with the 350 in it... so any advice!? im a 4x4 guy so dont know much about these old cars. thanks for any info! butch
Old 12-03-2012, 02:27 PM
Wiki Edits: 27
ford trans ?
Those old ford transmissions aren't very strong. They were designed to handle 85 horses. There were thousands of swaps done using them in the old days, you could buy an aluminum adaptor bellhousing, a new pilot bearing, a hurst front mount motormount crossmember , just not push it too hard, today the most popular thing is to match the engine up with an automatic, then convert the rear end to an open drive line type. and there are kits that use 2 parallel rear springs , and kits to add modern disc brakes to the front.
Old 12-03-2012, 02:36 PM
Ok sweet he wants to run stock tranny.. Where do I find the adapters? Can u post links because I have had no luck! Haha and what tranny is that actually?
Old 12-03-2012, 02:37 PM
Wiki Edits: 27
speedway time ?
speedway motors has the bell and bushing, $ 300, then it takes a 50's chevy starter I think, then Your radiator had 4 hoses, two outlets will have to be capped , then build the exhaust The front motor mounts also at speedway. $ 50 . google chevy to ford transmission and then motor mounts or just do the on line speedway catalog. They have lots of the old hot rod speed parts back in production . When he gets the flathead rebuilt the rat rodders will buy the chevy pieces not used.
Old 12-03-2012, 02:42 PM
Ok then motor mounts? And as for the the clutch, u use the stock off the flat head??? Thanks for the info btw!
Old 12-03-2012, 02:47 PM
Wiki Edits: 27
stock ?
most likely still the old side cover crash box. a synchro on 2 and 3 rd gear, a grinder first gear, the trans has the partial bell housing as part of the case. for racing lincoln zepher gears were swapped in, they had a higher speed 1 st and second gear. to beef one up more roller bearings added inside the cluster gear bore.
Old 12-03-2012, 02:52 PM
Wiki Edits: 27
clutch ?
speedway says to redrill a stock chevy flywheel but I think a 10 1/2 early corvette pressure plate with a ford truck disc 10 1/2 with 1 -3/8 shaft. It's been a lot of years. I last had a clutch rebuilder match the pressure plate with the disc I was using, size of disc and thickness must match for best results.
Old 12-03-2012, 02:53 PM
I'm only seeing adapters for a different tranny behind the flat head... Lol maybe I'm retarded but not finding em.. And so the clutch off the flat head will go back on ? And for a flywheel??
Old 12-03-2012, 08:17 PM
Wiki Edits: 27
speedway part numbers
the speeddway part no for the engine to trans 7200392
the speeddway part no for the engine to frame motor mount 91618005. read their instructions. it tells which chevy flywheel to use , and speedwway has a whole assortment of clutches. you will probably need some new cushions and mabe more frame brackets..
since he plans on running with the flathead eventually I would put in a the chevy engine with T 5 5 speed transmission with the S 10 shifter, convert to an open drive line or newer rear end, then when the flathead is ready, adapt the flathead to the T 5, It's a newer all synchro trans stronger than the old fords, amd the T 5 has the overdrive gear ratios.
Old 12-03-2012, 08:30 PM
Sweet!!! Thanks guys!
Old 12-04-2012, 05:32 AM
So what about the engine mount? Number 1
Old 12-04-2012, 05:35 AM
http://http://static.speedwaymotors....neMounting.gif
I don't know if the picture showed up on last post so here's the link
Old 12-04-2012, 05:58 AM
Wiki Edits: 27
mounts, speedway 916180005
My computer (actually my wife's desk top ) did not like the link , mabe popup's blocked..Good point about the motor mounts. the speedway front mounts or the old Hurst type, they work ok for hooking up the chevy to the flat head trans or for using the 50's chevy short transmissions that had mounts on the bell housings, The T 5 has the mount near the rear of the trans and with that transmission the engine should use the later mount location near the center of the chevy block. streatching out with a mount at the front of the engine and the trans at the back is not good, Rod and Custom and or Streetrodder magazines had several page articles about putting a T 5 behind a flat head, last year, I don't know what they recommended for motor-trans mounts, My old 46 ford truck has a Lincoln Y block and a truck trans that bolts up with stock ford parts. I just skimmed thru the articles I think there are motor mount kits for the chevy that use the center locations for motor mounts. bolt ons could be removed if they would cause interference when the flathead goes back in.
Old 12-04-2012, 06:03 AM
So what is that brace in the front of the motor?? And so I should not use speed way motor mounts? Cuz the way it will put weight on the tranny?
Old 12-04-2012, 06:08 AM
Wiki Edits: 27
more rambling
I don't know what 40's ford pickups with the open drive line used for motor mounts , when a stick trans with open drivelines were installed in a car you could get some clutch chatter because of the engine moving foreward and backward, the stock torque tube drive shaft bolted to the back of the transmission, keeping it from moving. In the old days there was a fix . There were U shaped brackets with a bolt in the bottom of the U that you slipped over the ctock ford front motor mount rubber "biscuits". You could tighten the bolt to preload the mount. I don't know how good they worked. I don't think my son used any when he had a flat head Merc in his 50 ford pickup.
37 ford door latch 52plymouth Body - Exterior 14 11-06-2009 07:18 AM
Fuel Door for 37 Ford? 37 in Salem Body - Exterior 1 12-17-2007 07:24 AM
Door handles replace 29 ford 2 door Steve Vento General Rodding Tech 4 06-08-2007 04:07 PM
39 ford door 39 ford Body - Exterior 2 08-11-2006 04:59 PM
31 Ford door glass 31 Ford A Body - Exterior 1 03-21-2006 08:05 PM
