Hotrodders Bulletin Board
#1
46 Ford
Hi..I am new and have a 1946 Ford Tudor that I am on the second frame off with. The first was based on a hot rod flat motor that will now go in a 34 ford pick-up. The current build will have a small block ford, AOD and nine inch ford rear. I have had to cut the X member build a new mount to get the AOD in but think it will be worth it. I live in the Texas Panhandle and it we do some long drives to get to rod runs. I am attaching some pics of the progress.
#2
re: 46 Ford
SR66
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! |
#3
re: 46 Ford
Welcome to Hotrodders, enjoy the site.
#4
re: 46 Ford
Welcome to the group. I started a 47 four door about a year ago but just moved to a new house this fall so it got put on hold until i get a new shop built. Have some pictures in journal. I'am using a 83 elCamino frame with 4 wheel independent suspension. 350 with 350 trans. most of frame has been a piece of cake. wheel base was perfect for 4 door and i just cut and welded in new rails before i cut off outer part of old frame rails so nothing to measure an every thing stayed just like chevy built it.
Back to top |
Similar Threads for: "46 Ford"
| T-5 transmission codes needed | xntrik | Transmission - Rearend | 4 | 09-06-2005 09:09 PM |
| 41 46 ford convertible ??? | Streetrodfan | Body - Exterior | 1 | 03-25-2005 05:10 PM |
| 46 Ford door hinge problem | woody51 | Body - Exterior | 4 | 09-11-2003 11:03 AM |
| 46 Ford door hinge problem | woody51 | Electrical | 0 | 09-10-2003 03:42 AM |
| drip rails 46 ford | carnut | Body - Exterior | 4 | 05-06-2003 09:59 AM |
