46 Nash - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2007, 06:58 PM
46 Nash
I have purchased a 46 Nash and need a wiring diagram for it in the worst way. See there is no key for it at this time and I need to find a way to start this car with no key as well as see exactly how the electrical is supposed to be set up. I know there are ways to do this but I do not want to tear it all apart with out the proper diagrams to put it back together correctly. I want to stay original as much as possible on this restoration. Any help is greatly appreciated.
Old 08-19-2007, 01:46 PM
327NUT's Avatar
See www.nashcarclub.org....somebody there could probably help you.
Old 08-19-2007, 07:01 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
FOR TESTING (only) :
Find the ballast resistor off the coil...(+side of coil, rectangle metal or ceramic box)
AT or near the coil...Connect a 12 gauge wire to an on/off Toggle switch, then to the battery. This is your Ignition.
ON THE STARTER: (Test ONLY!!! UNSAFE condition!!!!)
Locate the "S" Wire off the starter solenoid..
install a 12 gauge wire from here to a Push button momentary switch, then to the coil side of your toggle switch..This is your Start switch..
Turn the Ignition switch ON..then hit the PB, it will / Should Start..
BE ADVISED!!!!!!
you have NO NSS or Clutch over ride switch (S) in line..It will / Can jump and bite you or someone else!!! to safely do this you SHOULD have full "ON " E~Brake, Shifter LOCKED in neutral, and the rear wheels OFF the floor slightly..There are no "Do over's " for DEAD...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-28-2007, 07:56 PM
I have a wiring diagram for a '49.
Old 08-28-2007, 10:15 PM
you can get universial ignition switches for about 6 bucks
Shane
Old 08-28-2007, 10:45 PM
timing qustions
weres the comector 4 set timing on 94 gmc!
Home Brew's Nash comes home! home brew Hotrodders' Lounge 75 03-25-2008 05:30 PM
46 ford p/u model # ( WRONG ) ? biglee550 Suspension - Brakes - Steering 19 03-17-2008 09:45 PM
need advice on mating 46 1/2 ton to S-10 Frame Countilaw General Rodding Tech 0 05-17-2007 07:46 PM
Will a 46 ford suspension fit in a 41 ? Thunder Road Suspension - Brakes - Steering 1 05-13-2007 07:50 AM
'46 Chev pick-up front clip Sidn Suspension - Brakes - Steering 7 04-24-2006 08:53 AM
