Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 46 Rh questions
Thread: 46 Rh questions
Old 01-22-2013, 11:50 AM
FabioV8 FabioV8 is offline
46 Rh questions
I have a Land Rover Defender 390 stroker mopar engine and transmission 46RH that use only in off-road,I redid my 46rh using a kit Trans-scat in Heavy Duty model
my engine does not use an original ECU, and no longer manages the lock-up and the 4th, how can I manage them? I can put two external switches?
the lock-up must operate only when I trigger the switch on the 4th?
