Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 460 Aod?
Thread: 460 Aod?
Old 07-10-2006, 03:13 PM
ABRAXS ABRAXS is offline
Originally Posted by ABRAXS
I'm working on a '76 Lincoln twn cpe with a 460. I want to install an aod if possible. I was told that a 400m bellhousing would work. I also found an aod out of an F-250 (91) will they work together or do I need other parts to complete the swap? Any help will be appreciated.
I should have been more specific. I know there is no 400m it's a 351 m-400. There is supposed to be an aode trans that I'm told has a seperate bell and trans. That is the trans with the 400 bellhousing that I'm looking to use.If I'm incorrect about this I have been misinformed.Thanks again for any info supplied.
