460 bbf engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2013, 06:51 PM
460 bbf engine
I have been looking at the Ford 460 as a tow motor for my hot rod. In the junkyard they are dirt cheap. After doing some math the cost to build is about half that of the bbc 454.
$100.00 complete carburetted engine
re-ring kit with crank and rod bearings gaskets $67.00
performer intake $100.00 EBay used. Holley 3310 750 vacuum secondaries, used EBay $40.00.
Hand lap the valves in cost $12.88
lapping compound and lapping stick.
Howard's towing camshaft $52.00
Headman 1 3/4 primary tubes headers. $90.00
Thats it, now for the grand tally $461.88
For myself thats not to bad with the complete motor in the total tally
Old 10-09-2013, 07:04 PM
Proud LOSER
You forgot your 650000000 volt coil
The Following 2 Users Say Thank You to bygddy For This Useful Post:
68NovaSS (10-09-2013), vinniekq2 (10-09-2013)
Old 10-09-2013, 09:08 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You will not rebuilt a 460 Ford motor for $461.00, even using what could wind up being ripoff junk from fleabay. Don't forget shipping, ignition, lifters, gasket set, hone, two oil changes with filters, spark plugs, etc, etc.
Semper Fi
Old 10-09-2013, 09:54 PM
"cheap junkyard engine build"
I have called already here at my local junkyard for the complete engine and I always get free shipping or I don't buy it. I have hones and tools here at home for rebuilds. I know how to scrounge around and get what I want for the price I want to pay. I have friends that will give or loan me parts for nothing. Or I don't get it. Thats the bottom line. I've had to do this all my life so now you tell me!?!?
Old 10-09-2013, 10:04 PM
vinniekq2's Avatar
mods? there isnt a question for discussion in this thread?Can it be rewritten or adjusted? I dont want to enter a post about the math and start a silly fight
Old 10-09-2013, 10:29 PM
blwilliams's Avatar
Best of luck on your rebuild.
Remember this, they are called junk yards for a reason.
Think about this. How many miles will your used engine have on it. What are the chances of the engine being left out in the open and rain getting into any cylinders with the intake valve left open?
I wish you the best but I have opened up plenty of "quality" pre used engines and they are not very good candidates for a quick ball hone and new ring and bearings.
Like already mentioned you should at least install new lifters on your new cam.
Old 10-09-2013, 11:58 PM
a dilemma in a pickle jar
I take my tools to the yard, the owner says it's ok to pull valve cover and oil pan if needed. Also a drill and a modded screw driver to check the oil pressure.. I would never buy a engine that was left outside with no cover on it.. All his engines are covered and clear plastic wrapped and taped. Nobody in there right mind would would purchase a froze up engine laying out in the elements.Most engines nowadays are still in good shape cause the low compression and mild rpm.s they turn. The last two engine I've got fton our junkyard have been a ok. We go out to the countryside about 30 miles out and. Those old junkyard people are as honest as you could ever imagine. Lot of there parts are quote make me an offer and 99 times out of 100 thats what you pay. Now you know the rundown. I hope this helps.
Old 10-10-2013, 01:42 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Agreed, more of a story. Doesn't fit in the lounge, moving to general tech.
Semper Fi
Old 10-10-2013, 01:43 AM
JeffB's Avatar
460 BBF's make a ton of torque,"Git "Er Done" and let us know how it turns out,love to hear about "budget builds" not all folks are blessed with a fat wallet
Old 10-10-2013, 02:19 AM
thanks for the inspiration and your good luck to me goes along way in my book.
that is for sure, Thats why i'm not going to spend money I don't. have The e7te fuelie heads se peanut port intake openings and have 64 xx chambers. The early heads have from 72 cc's to 74 cc chambers
that gave 8.0:1 compression. the fuelie heads have 62 cc's. For a full point raise in compression to 9.0:1 so there is some gas mileage with these heads & junk yards know through their inventory what the do or do not have. I'm 59 years old so I have been around enough to know by looking at parts if they are good or bad. Not bragging but just facts. Believe me or not I don't care one way or another.
Cheers to you all,
Have a blessed nightn Arless
Old 10-10-2013, 05:09 AM
Proud LOSER
Cheers to you all,
Good luck with your build
Old 10-10-2013, 06:35 AM
Oh i've checked all right. that is the first thing I did. and if you are referring to to the miss match of intake ports. Mustangs and fast fords said it doesn't matter at that low hp and rpm. Oh I will have to use the stock valve cover's. The the bolts are in the center of the heads
Old 10-10-2013, 06:50 AM
Cheers to you all,
The 460 fuelie heads have a 96cc chamber. The small block heads with the same casting number are 62cc. The fuelie heads have different intake and exhaust port dimensions than the standard passenger car heads. Only the factory cast iron intake will work without modification.
There are no aftermarket intakes available for the fuelie intake port layout. Someone may be making adapters by now, not sure. An aftermarket intake intended for the standard intake port layout can be modified to work but it is a lot of work.
If you are using a post '71 short block the C8/C9/D0 heads are the way to achieve 9:1 compression.
Old 10-10-2013, 07:34 AM
here we go again, I stand to be corrected the heads are 62cc heads for the 460, there was only one year that ford had a completely open chamber head that was 1973. The new heads are 62cc chamber cc's. there is a adapter plate for the heads to mount any intake you want.
Old 10-10-2013, 08:13 AM
arless,
"Hand lap the valves in cost $12.88
lapping compound and lapping stick."
Truman's back in the White House?
This isn't a lawn mower and time is money SO
a low speed-reversible drill, some fuel hose and clamps, very much faster.
good luck with it.
BBF 460 vs 503 stroker? matt167 Engine 5 02-03-2012 07:56 AM
Bbf 460 Vibora Engine 8 01-14-2011 07:40 AM
BBF 460 Heads 1967chevelle454 Engine 2 01-31-2010 11:27 AM
460 BBF... Side-Oiler?? jumbobumbo101234 Engine 1 05-04-2008 01:19 PM
460 BBF Build chevy350_Camd Engine 4 01-13-2008 11:10 AM
