460 big block - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2012, 02:36 PM
460 big block
can you take the crank out of a 460 big block or any at that without taking the pistons and the rest of the top of the motor apart??
Old 03-26-2012, 04:08 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Yes but it's not adviseable it can really be a "PITA" if you have not been done that road before. Other words it's not a easy chore, Is the engine still in the vehicle or what exactly is the reason you are wanting to do it this way ? needing a new bottomn end ?
I would suggest you getting a good book/manual on the subject before jumping in and m some help if you can find some.IMHO
Cole
Old 03-26-2012, 11:02 PM
I would pull the engine.for crank being removed. I think metal would be all up in. That engine.
It can be done on. But will need extra hands. And help you going to sell it after that
Old 03-27-2012, 02:23 PM
Cole
the engine runs good but has a slight knock cause the idiots before never bothered to change the oil. it doesnt burn oil or anything just has that slight knock and just didnt feel like doing a full rebuild yet because i think the motor has life in it yet.
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 07:36 PM
Can You I D a Block & Heads Small Block Chevy please? Rob Keller Engine 19 01-30-2011 08:39 AM
Long block short block fitted block what do opelitis5 Hotrodding Basics 4 01-10-2010 06:12 PM
Need advise for trade. 408 short block for dart iron eagle block sherman8r Engine 6 12-06-2009 04:37 PM
can i use small block motor mounts for a big block? 402 Camaro Engine 5 01-25-2008 07:33 AM
