Internally, this looks like a great combination. You've nailed the camshaft and it should pull hard from 3,000 to 6,500.
Externally, I think you're gonna need more carburetor. |
So if I took a 850 double pumper could I convert it to run e-85 or do I need one built for it? I have an 850 sitting around. Im thinking that the bleeds need to be larger for the ethanol though?
I think that the motor set up sounds good.
I think I would prefer putting the motor in a vehicle with a longer wheel base. I have seen and driven short box Rangers that were set up like yours with half of the potential HP and they were still very difficult to keep strait when you hit the throttle. |
Everything looks good. As posted above, the carb might be a bit small. Depends on how high you plan on revving it tho.
Have you checked out www.460ford.com ? Lots of great info there.
http://www.hardtail.com/techtips/alcoholconversion.html |
Thanks for the links I'll have to go take a look. The ranger is just the first thing I could get cheap that was light and I could practice my 4 link setups on with out caring how badly I destroyed it. I will someday put the engine in something more deserving. I am also thinking about having the heads reworked for the cobrajet valve size what is it 2.25" intake and I cant remember if the exhaust changes. I have heard the normal heads with the larger valves will outflow the cj and scj heads ( for street use)
In the builds I have found I have seen a lot of people use the trick flow street heads, I cant afford aftermarket heads right now but I am going to bigger valves in my C9VE heads and porting the exh. port. Any Idea if I would benefit from a 2.25" intake valve as opposed to the 2.18" valve? I currently have 2.08 valves. I dont want to go overboard but the valves cost the same
bigger better or will I loose my velocity?
from what I know of those heads a 2.25 valve doesnt do any good. Causes a reduction in velocity making the port lazy. And for those heads it would be lazy in most of the power band.
When I had my heads ported 2.19 intake 1.73 ex valves where installed by the person doing the porting. |
You don't want the intake valve too close to the cylinder wall. If you shroud it, you disrupt the mixture kernel and lessen flow. I'd go with the smaller valves, they'll be plenty in my opinion.
| Unknown Ford 460 engine | Stovens | Engine | 3 | 10-28-2007 07:58 PM |
| Unknown Ford 460 engine | Stovens | Engine | 6 | 10-06-2007 02:22 PM |
| Ford Anglia / 460 Ford Help | martin UK | Introduce Yourself | 1 | 12-19-2006 01:19 PM |
| redline for a 460 ford? | Trav | Engine | 1 | 02-02-2004 07:37 PM |
| Whatever happend to these guys? | hot_rod_kid | Hotrodders' Lounge | 20 | 12-17-2002 09:20 AM |
