460 Ford Engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2010, 01:53 PM
460 Ford Engine
Can anyone tell me the year of the above engine? The number on the block just above thr stater is DIVE-6015-A2B and the number on the intake Manifold is D6vE-9425, the stamp circle reads 97- 58. Thank You
Old 11-24-2010, 01:58 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Looks like the block is a 1971 and the intake has a 1976 casting # on it , Hope this helps.
Cole
Old 11-24-2010, 10:09 PM
techinspector1's Avatar
Wiki Edits: 326
Let me warn you about one thing....if you are rebuilding this motor, use a timing set from a '68-'71 429. The later timing sets will retard the cam by up to 8 degrees and you won't like the results. The '68-'71 429 chain and sprockets are manufactured at zero, neither advanced nor retarded. They'll bolt right into a later 460. I don't know how many times I have read of fellows using the '72-up timing set and then wondering why the motor won't pull the hat off their head.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
Issue with Ford 460 clutch onebadmerc Transmission - Rearend 1 02-22-2007 06:15 PM
Ford Anglia / 460 Ford Help martin UK Introduce Yourself 1 12-19-2006 01:19 PM
460 ci ford engine help shootingstar General Rodding Tech 4 09-19-2003 09:49 AM
