460 ford idling issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2012, 10:01 PM
got a 460 big block ford all mostly stock has edelbrock performer intake and edelbrock carb dont know size but the other day was driving it and it ran good like it normally did then i got into into i pretty good then it started running like it was out of gas and it almost was so i put some gas in it but it idles rough like it isnt running on all cylinders but if you get up in the rpms it runs fine. then i was messing with it checking sparkplugs and such and took of the vacuum line going to the vacuum advance and the idle stayed the same still idling rough??
Old 06-18-2012, 07:22 AM
Irelands child's Avatar
First of all, the carb model number is on the pass. side corner facing forward and near the bolt hole. It will be 14XX in .25 numbers.
These carbs are very sensitive to dirt and almost running the car out of gas, may have sucked some through. They just wont idle, but will run kinda OK at higher throttle.
Super simple to clean out - assuming you have the Torx drivers. Two screws to pull the metering rod covers and then the metering rods out, eight to pull the top cover and 2-3 tiny spring clips for the linkage. You are now inside then manually clean out the bowls. With the top cover in hand, pull the floats, then the needle and seats(keep these parts matched as to where they came from or face resetting float level and drop) - there is a screen on the casting side of the seat that gets cruddy, clean it off.
Unless you have at least a gasket kit, do NOT pull the 10 screws inside the carb as the gaskets often stick and get torn apart - regardless, you don't want to do that with the carb on the engine.
These are fun/simple carbs to work on - I just fully rebuilt two of mine this past week.
One is ready to be reassembled, the other you can just see at the top of the photo
Irelands child
Old 06-18-2012, 07:51 AM
Wiki Edits: 27
Egr ?
If you still have the EGR, how is it a slight coincidence it started leaking at the same time.
Ford 460 BB rbejaisingh Hotrodding Basics 6 09-20-2010 10:53 PM
Ford 460 Chevy 84 Engine 2 08-06-2010 08:05 AM
help w/ tunnel ram idling issues bobo1955 Engine 30 03-05-2010 09:37 AM
diagnosing blow by issues with 460 cboy Engine 24 06-15-2005 06:37 AM
289 idling issues femadorob420 Engine 7 02-06-2003 03:26 PM
