460 ford into 87 f 150 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2012, 02:26 PM
dont know how this works, so here goes. what size flywheel will i need? have zf 5 spd going against 1974 lincoln 460 its internally balanced. flywheel needs 0 balance. how many teeth on flywheel for this conversion. remember starter bolts to bellhousing bellhousing is part of zf 5 spd. thanks g
Old 01-09-2012, 08:46 AM
im deaf, and all i asked for was how many teeth on the flywheel. why the sarcastic remarks.
Old 01-09-2012, 05:47 PM
T-bucket23's Avatar
Wiki Edits: 26
he was a spammer. Post removed. You should get an answer soon
Chet
Old 01-09-2012, 06:07 PM
Thank You, They List 2 Flywheels A 184 And A 176, And Im Sure They Both Cant Work In The Same Application. Thanks Again
Old 01-16-2012, 08:04 PM
junkyardjeff's Avatar
Any pre 79 truck 460 flywheel should work,I think 79 is the year the motor went to be externally balanced.
Old 01-16-2012, 11:04 PM
460 Ford
Thanks Jeff For The Info, I Still Dont Know What Flywheel To Use. My Eng Is Internally Balanced, Its Out To 521 And Ive Got A Zf 5 Spd Behind It. So The Starter Bolts On To The Zf, There 2 Flywheels Listed A 184 And 176 Tooth. I Have To Use A Neutral Balanced Wheel And Balancer. Crank Is Mallory Metal Balanced.
Old 01-22-2012, 09:40 PM
I don't think that the tooth count will matter as long as you use the right starter (for the tooth count). If it has counterweights it's externally balanced. All of this is a lot easier if you can find a good parts man, a salvage yard that caters to 4wd trucks would be a good place to start.
Old 01-22-2012, 10:02 PM
Thanks Pete If What I Have Doesnt Bolt Up Rite , I Could Probably Increase The Amount Of Teeth On The Starter, Ive Already Bought The Parts, They Are New. Its A Lot Easier To Change A Starter Than A Fly Wheel.
Old 01-23-2012, 04:08 AM
Wiki Edits: 31
you would have to convert the entire engine to external balance unless you took the external balance flywheel and machined off the counterweight. a 390 flywheel will fit, but it's 3/8" thinner and may not work right with the late bell housing.. 460 4spd trucks didn't exist until 1981ish ( at least to hollander interchang ), so your just going to have to make stuff work to use the linc motor..
Old 01-23-2012, 09:04 AM
matt thanks for the response. ill tell you whats goin on. i have a 460 1974 linkon eng i put a scat 521 rotating assembly internally balanced, i used a centerforce 176 tooth flywheel 0 balance. the bolt pattern on the zf 5spd goes on the linkon eng. if a later mdl 460 had a 176 tooth flywheel i should be ok. i dont expect the zf to last to long but i should be able to move the truck. my other thought was use a larger starter gear, if this combo needed a 184 tooth flywheel. thanks for your input. g
Old 01-23-2012, 04:46 PM
Wiki Edits: 31
The ZF should hold the power, tho if the clutch blows, it will take out the housing.. Your CF flywheel should be drilled for a clutch that will work with the ZF trans.
Old 01-23-2012, 05:26 PM
thanks again. g
1948 Ford stock engine/tranny with Ford 9" rear end beek15853 Transmission - Rearend 5 04-04-2012 07:56 PM
1992 Ford Exlplorer differential into 1946 Ford ? bgraham Transmission - Rearend 1 06-28-2011 02:35 AM
1934 Ford transmission with1948 Ford truck engine clutch questions ppetrano Transmission - Rearend 1 05-20-2011 11:02 AM
1932 Ford rims Kelsey Hayes or Ford motor Co. alf51chevy Suspension - Brakes - Steering 2 09-12-2005 08:14 PM
Ford Racing Visteon Ring & Pinion, 9" Ford ??? acr Transmission - Rearend 2 07-23-2004 09:17 AM
