460 ford question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2008, 08:27 PM
460 ford question
I have a 460 Ford engine I believe to be 1970s. I need to know how to find casting numbers and or dates to see what exact year I am dealing with or possible ideas about what heads and etc. are good vs. not so good. I need to know more about these big blocks and what options were available like heads, intakes, etc. Any help would be greatly appreciated or where I can turn to find info without hours and hours searching.
Old 10-08-2008, 09:51 PM
53fordguy's Avatar
Junkyard Kustoms
Last journal entry: update after a long time
posting a head casting number would be a good start,ford stamped letter in them to identify years c,d,e aka 60,70,80's and then a number d0ve 1970(good heads)or like c9ae 1969.
what did you get the engine from? that also helps determine whats in the engine,
53 fords rule!
Old 10-08-2008, 10:22 PM
ford 460 question
the motor is in a 1977 f250 truck. I bought the truck with intentions of strickly mudding use. the truck used to be a stick trans with I am guessing a divorced trans case, 44 front and dana 60 rear. It now has married trans c6-205case and 460 engine. I am not sure if this is the motor that was used from factory. there is a vin plate on the door post and door of the truck. also the letters on the head are d3ve-a2a thanks again !!!
Old 10-08-2008, 11:11 PM
techinspector1's Avatar
Wiki Edits: 326
Good heads. 96cc chambers.
Old 10-08-2008, 11:43 PM
460 ford question
I am looking at putting a used torker intake on this motor. I know this intake is a single plane rated for higher rpm use. Would it work on this stock motor and what size carb would the original motorcraft spreadbore have been for this engine? I cant reuse this carb as it will not fit on the square bore type manifold. The original manifold on the engine now, the previous owner took off the plate that sits below carb and has a provision for the choke stove set up so now I have raw exhaust coming out of intake and a huge leak underneath the carb. Thats why I am considering using the torker intake and diff. carb. I know the intake is extreme for stock use, but will it work at all or should I find something else? THANKS AGAIN FOR ALL REPLIES!!!
Old 10-09-2008, 09:40 AM
onebadmerc's Avatar
I need a bucket of arc sparks
If I was to guess your block casting number it would most likely be a D1VE or a D8TE block, both are good blocks. As for the stock Motorcraft 4350 four barrel carb, it was rated at 600cfm but probably only flowed more like 500cfm. I used the stock spread bore intake on my 78 F250, I bought a adapter plate for $20 and bolted a 600cfm Edelbrock on it. This is a stock engine and it seems to be happy with this carb.
Old 10-09-2008, 10:55 AM
460 ford question
I have a carter afb that I am guessing is a 650cfm. I have not read the numbers yet to see, but I will do that. I was thinking of using this carb on top of the torker intake and hoping that the engine will run OK with everything else being stock. There are numbers on the pass side back of enging that start out D1VE.......... Is there a way to determine the exact year of build like a casting date and if there is, where would it be located. I noticed also that there are two different intake gaskets for diff. year motors and am trying to figure those out so I can order intake gaskets. Some years use valley tins and others regular side gaskets
Ford 460 vs 351W GranTorinoElite Engine 12 05-30-2007 10:31 AM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 07:31 PM
460 Ford wont turn over. Please advise!!!! slider in wa Engine 4 10-23-2004 09:22 AM
460 ford a good motor? Trav Engine 4 12-10-2003 04:11 PM
89 efi 460 motor in to 78 ford ltd wagon 74bubba Engine 3 07-28-2003 08:56 AM
