Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 460 head removal
Old 11-19-2012, 07:25 AM
delawarebill's Avatar
delawarebill delawarebill is offline
pull'n the head
wondering if u did a compression test first ??? do a dry one and then squirt some oil in the cyl and turn it over a few times and do another.. if stays the same either everything is ok or the valves are bad.. if goes up the rings are leaking... i'll assume u have ck'd for electrical problem...
