Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 460 head removal
Old 11-19-2012, 04:55 PM
lil-vulky lil-vulky is offline
iv brought a brand new hei dizzy new leads new plugs done compression test was 140psi, only done a dry compression test, havnt got a leak down tester thingy mechanic was meant to do that friday but he never came around. took the rocker cover off and wound it over everything moves as it should,
it only misses on number 6 cylinder, it runs when u first start it once it cold for about a 30seconds fine but when u try and rev it'l miss and the warmer the engine is the worse it misses, only thing really i thought it could be is a cracked head,head gasket or a stuffed valve not sure what else it could be
