whats EGR? and how do i check that? ignition is all new so should be fine i swapped plugs and leads with another cylinder and the miss stayed on number 6, and what do you mean by carb base gasket and intake leak? how would i go about checking that.
i thought it wouldnt be the carb because if it was wouldnt it miss on all cylinders not just the 1?
