Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 460 head removal
Old 11-20-2012, 08:15 AM
MARTINSR MARTINSR is offline
Originally Posted by lil-vulky View Post
whats EGR? and how do i check that? ignition is all new so should be fine i swapped plugs and leads with another cylinder and the miss stayed on number 6, and what do you mean by carb base gasket and intake leak? how would i go about checking that.
i thought it wouldnt be the carb because if it was wouldnt it miss on all cylinders not just the 1?
When did this miss show up? Was it BEFORE all this stuff was changed?
