460 keeps dying - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2008, 06:26 PM
72 grabber 51F-1 65 chevystang
460 keeps dying
I am asking this for a friend. he has a 78 F-100 4x4 with a 460. It has a 600 holley on it. It will stop running randomly and runs real rich. He said it will crank fine. I was wondering what could cause this. Thanks for ny help
Old 10-20-2008, 06:50 PM
460 dying
hi have your friend to ck floats may be sinking or power valve
Old 10-20-2008, 06:56 PM
T-bucket23's Avatar
Wiki Edits: 26
You may also want to check for proper choke operation
Chet
Old 10-21-2008, 06:23 AM
Irelands child's Avatar
My history with older Holley's and crappy running is that the power valve has gone to heaven, usually from a backfire while starting cold. Later Holley's have a check valve that will usually prevent these failures and there is a 'kit' that can be installed as well for less then $15 from Summit (their p/n Hly-125-500) plus a new 6.5 power valve.
Once that's fixed, then the choke usually needs some attention.
Another problem with Holleys - throttle shaft wear (Summit p/n HLY-20-48-1 for a 4160 is one of several repair kits)
Then - it might just need a major overhaul or just plain need to be trashed and a new one installed
Old 10-21-2008, 09:02 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Our motorhome with a 460/holley was idling pig rich at about 400 rpms.
New power valve and a little tune up cured it.
Old 10-21-2008, 09:13 AM
Jmark's Avatar
You may have two problems. In the '70's, the Ford ignition box gave everyone fits. If your friend still has the Ford electronic ignition, have him change the box. It's the silver rectangular box under the hood. It's about 5" square and has two wire harnesses coming out of it. The main symptom was the engine would just shut off for no reason, then usually fire back up again after coming to a stop and sitting for a few seconds or minutes.
you may also have a carb problem too. A blown power valve (very common) will really fatten up the mixture and cause smoking and horrible mileage.
Mark
All Aluminum 460 Block thunderbird87 Engine 14 06-01-2007 07:28 PM
Ford 460 vs 351W GranTorinoElite Engine 12 05-30-2007 09:31 AM
Issue with Ford 460 clutch onebadmerc Transmission - Rearend 1 02-22-2007 06:15 PM
460 flywheel, 400 pressure plate? billybob_v10 Transmission - Rearend 2 07-02-2004 11:51 AM
carbed 460 or EFI 302 CustomFord Engine 2 04-16-2003 04:23 AM
